access to element of a subTable in HierarchicalTable
Postby nicola.gioia » Mon Dec 12, 2005 9:05 am
I have a HierarchicalTable on which the method getChildValueAt(int i) return a TableModel with a variable number of rows.
When the TableModel change the values returning less rows it will exec the fireTableDataChanged() method, but the subtable display always the same rows, that was present when it was expanded: also the deleted rows.
The only way to update the rows displayed on the subTable is manually collapse and expand the subTable.
How can I force the update of the structure by code without collapse and expand the table?
nicola.gioia
Postby JIDE Support » Mon Dec 12, 2005 9:22 am
refreshRow(int row).
Postby nicola.gioia » Mon Dec 12, 2005 9:59 am
I think that the refreshRow(int row) method must be called on the HierarchicalTable instance. But there is no way to do the same without using the Table, but using only the TableModel? And what do the method do? It is not present in the JavaDoc of JIDE
nicola.gioia
Postby JIDE Support » Mon Dec 12, 2005 10:03 am
It is indeed on table level. There probably should a fireXxxEvent thing on HierarchicalTableModel for this purpose. Can you somehow get the table to use it as workaround? I'll think about how to make it better.
Postby nicola.gioia » Tue Dec 13, 2005 3:50 am
I have some problems to get the table, because I am working with an array of HierarchicalTableModel that have no reference to the associated tables.
nicola.gioia
Postby JIDE Support » Thu Dec 15, 2005 12:16 pm
I made it calls refreshRow automatically when you fire row updated event. Will it work for you? I put a quick test patch at http://www.jidesoft.com/evaluation/jide.1.8.6.eval.zip. Can you give it a try and see if it works?
Postby JIDE Support » Fri Dec 16, 2005 1:27 am
It looks like you haven't got a chance to try the beta. Anyway, just so you know, this bug fix is included in 1.8.6 we just released.
Users browsing this forum: No registered users and 74 guests
